3 input NAND Gates for function
Discussion in 'General Electronics Chat' started by Adriana, Nov 15, 2014.
  1. Adriana
    Nov 15, 2014
    Hi all!
    I have a 74HC10 component with 3 input NAND-gates and I am trying to use it to connect a function which is
    X="overline/inversion of"(AB)
    Could someone please help out with the circuit diagram?
    I am not sure what to do with the third input in the NAND-gate.
    /Adriana
  2. djsfantasi
    Apr 11, 2010
    2,911
    881
    Is the function you describe ("X="overline/inversion of"(AB)") look familiar? It's a common logic gate…
    As far as your question about an unused input, draw out the truth table for a three input NAND gate. Look at the output if one input is tied low. Is it the same as the truth table for a two input NAND? Repeat the exercise if one input is held high. The result of this exercise will show you what to do with the unused input.
  3. shteii01
    Feb 19, 2010
    3,516
    515
    (AB)' isn't that De Morgan's Law?
  4. Adriana
    Nov 15, 2014
    Sorry Im not really following, could you please elaborate?
    I have done the truth table, but still dont get it..
    Btw yes X=(AB)' would have beena better way to express the problem statement :)
  5. djsfantasi
    Apr 11, 2010
    2,911
    881
    Here is the truth table for a 2 input NAND gate, which is (AB)'
    And for a 3 input NAND gate
    Now take a look only at the portion of the table where A is low. Do the columns B, C and Y look like a 2 input NAND gate? Do the same exercise for the portion of the table where A is high (A=1)?
    What value should you tie an input of the unused pin of a 3 input NAND, for the remaining pins to act like a 2 input NAND gate?
    Adriana likes this.
  6. ian field
    Distinguished Member
    Oct 27, 2012
    4,459
    792
    The basic AND will output logic one only if every input is logic one. The NAND is just an AND with an inverter on the output.
    You can tie an unused AND or NAND input to Vcc.
