3 in 1 ;)
Discussion in 'General Electronics Chat' started by hazim, Nov 30, 2009.
  1. hazim
    Thread Starter Active Member
    Jan 3, 2008
    419
    13
    Here are 3 small questions that made me "twiddle" in the last few days...
    1) What is this thing found in most appliances connections before the plug? (see the attachment).
    2) In a simple dc analysis of an NPN transistor connected in common emitter,
    (E is connected to the ground), and we have only Rc and Rb. Current Ic = βIb, then Ic = β(Vcc-0.7)/Rb. Here is the question, isn't Ic related to Rc?! it seems to be not logical. I even tried it on Multisim with Rc in a potentiometer, as I changed the value of Rc, Ic changes obviously.
    3) I searched a lot for an RF controlled switch circuit but I didn't find any. I need a simple one with a transmitter and a receiver which only task is to switch a relay when it detects the RF transmitted from the transmitter.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It's a ferrite for RFI/EMI suppression. The device powered by the plug is most likely a switching regulator. Switchers can generate lots of electrical noise in high frequencies; the ferrite blocks it.
    Sure, Ic is related to Rc. It will limit the maximum current flow.
    If you're operating the transistor in the linear region, you will effectively have a current controlled voltage divider; the Ib controls the Ic up to the point of saturation, where increasing Ib does little to increase Ic.
    Did you look at Mini Circuits site?
    http://www.minicircuits.com/
    It would help if you more fully described what you are trying to do, but you really should put this question into a separate thread with a more specific title.
  3. hazim
    Jan 3, 2008
    419
    13
    Thank you, you answered my first two questions... but for the last one, it may needs a separate thread yes but the site you mentioned, minicircuits.com is a commercial site only as I found. If there are schematics in it then please give me the specific link where they are.
  4. hazim
    Jan 3, 2008
    419
    13
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I guess you really don't want an answer, because you haven't started a new thread for that specific question.
