I do have Resistors on the NPN bases. Isn't that limiting the current to the BASE? There is NO resistor on the PNP though. Should there be? These Input are coming from Transistors themselves. NOT full battery 12v and Ground.You should limit the current into the transistor base for two reasons. 1) there is a limit to how much current a bipolar transistor can handle. 2) the logic device supplying the signal can only source or sink a limited current. Ultimately, not good for the coming or the going. 20 mA is normally about as much current as you should expect from a Microcontroller pin. Some are less, some are more. 20 mA is a good start.
I have also attached the finished schematic of this circuit I made in Altium Designer.
TONY
