3 chips lost by single button press
Discussion in 'The Projects Forum' started by mah, Mar 7, 2014.
  1. mah
    Thread Starter Active Member
    Mar 15, 2010
    276
    in the attached circuit i use analog signal to drive buck converter by atmega8 and it was working well . i connected MCP617 on the same breadboard to measure current in the circuit using zero ohm resistor . supply for atmega8 and the op amp from lm7805 where the input for lm7805 is 12 volt which was used as supply for IR2112 . when i add the op amp circuit i forgot to connect the negative terminal of the load to pin 3(+ve input) of the op amp then i switched on the power supply or the battery .i couldn't even see any signal the driver got very hot and the op amp ,but the atmega 8 didn't get hot but there was no output from it. i don't know what happened ,why did i lose the three ICs
      File size:
      35.1 KB
      49
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Always measure output from voltage regulators before connecting.
    And use a LED, that will tell you abnormal voltages as well.
    If you are paranoid, use a zener diode 5.6V and a fuse. No seriously, it costs money and takes efforts to replace chips.
  3. mah
    Mar 15, 2010
    276
    the output of regulator is 5 v and it can't exceed this value .i will lost my mind what is the reason that burnt those chips all of them and which one burn the others . please if any thing is n't clear you may ask
  4. wayneh
    Sep 9, 2010
    12,391
    3,246
    Help me understand: The circuit above the red and green circled areas, everything other than the op-amp circuit, was working fine. You then added the op-amp circuit and did what?
    I also did not understand your reference to a "zero ohm resistor".
  5. mah
    Mar 15, 2010
    276
    zero ohm resisitor (resistor in m ohm) .006 ohm
  6. wayneh
    Sep 9, 2010
    12,391
    3,246
    I should have used a question mark:
    The circuit above the red and green circled areas, everything other than the op-amp circuit, was working fine?
    Please be precise about what was working, and then what you did that caused the problem. Reference your drawing. I still cannot follow your words.
    A photo of your build might also help. It is very easy to make wiring mistakes or to get a pinout wrong.
