3 chip digital clock ?
Discussion in 'Homework Help' started by Emuuu, Dec 7, 2004.
  1. Emuuu
    Dec 7, 2004
    6
    Hi I am Bob
    I heard that you can build a digital clock with only 3 chips, how do you achieve that and what sort of accucary does it give and what sort of display does it use ?
    Thanks alot. :lol:
  2. Brandon
    Dec 14, 2004
    306
    Actually, you can do it with just 2.
    Microcontroller + LCD Controller Chip
    You choose the level of information you want to display. You can usually purchase an LCD and its corresponding controller as a package. Your choice of micro should permit the use of an external crystal as a clock so your accuracy will be very tight.
    It would be as accurate as you program it and as accurate as your main timing device. Crystals usually give very accurate timing.
  3. spirit_viewer
    Jan 11, 2005
    Correction...
    You can actually do this task in a single device, for example a single PIC (16F84) which you can program to keep the time and drive directly a 16x1 LCD.
    I'am sure with enough thought you could include date, alarm settings, buzzer control for the alarm and perhaps even choice of a tunes to act as the alarm.
    Where would we be without PIC's !!
  4. cyberhehe
    Oct 6, 2004
    61
    You can do it with a single MCU with built in LCD driver and make use existing any existing glass out there as long as it supports the number of front planes (segments) and Backplanes (commons) the MCU is capable of. Can operate as low as 1.5V
