3 channel spectrum analyser questions
Neil Groves
Joined Sep 14, 2011
125
Hi Guys...i am building the circuit that i have supplied a link to but can't find any info about how it works, setting up or testing, so far i have built the input stage and the top filter (u1a and u1b) respectively, on feeding the input with a gorgeous sinewave, everything looks good untill the signal comes out of pin 9 where is is ringing badly? i don't know what to expect at the output, i am assuming that as the frequency changes, the voltage at the output rises and falls respectively as it does on mine, i expected a clean rising and falling D.C voltage at though instead of a peaky waveform at the Cathode of D1 though, can anyone give any insight to this circuit please?
I am aiming to be able to hook up my signal generator and sweep though 40Hz-16Khz and seeing the leds sweep through from bottom to top as the frequency rises.....or am i mistaken about what this circuit does?
Neil.
http://www.aaroncake.net/circuits/3chspec.asp
http://www.aaroncake.net/forum/topic.asp?TOPIC_ID=8847&
Neil.
Audioguru
Joined Dec 20, 2007
11,248
Hi again, Neil.
I think that type of peaking filter has a bandpass that is too narrow to do what you want.
You need filters that have a flat bandpass then complementary slopes like the crossover network for a speaker.
Neil Groves
Joined Sep 14, 2011
125
These graphs show me EXACTLY what i was seeing on the scope as i varied the input frequency, a sudden spike instead of a gradual rise and fall....you guys are so bright!!!!!
i have a couple of projects i really need to finish then i am going to sit down with a book or two and learn this stuff, is there a formulae for calculating filter frequency response?
Neil.
SgtWookie
Joined Jul 17, 2007
22,230
There are lots of different types of filters.
For this type of thing, you need three different types:
1) A low-pass filter for the low frequencies - everything below a certain frequency can go through.
2) A bandpass filter for the midrange frequencies - usually specified by a center frequency and a width. Everything outside the band is rejected. This consists of a high pass with a low frequency roll-off, and a low pass with a high frequency roll-off. They can be combined into one stage.
3) A high-pass filter for the high frequencies - everything below a certain frequency is attenuated.
These ranges don't have to be absolute. A Butterworth type filter will provide smooth transitions between the various frequency ranges.
