Hi
I'm looking to build a 3 channel RGB led PWM dimmer that can be controlled via IR using an all in one remote that currently runs the home theatre set up.
I want to be able to set a macro on the remote to dim all three RGB channels to a set point, probably by IR signal receive timing, ie the longer IR is received the brightness ramps 100% to 0 and back to 100% cycle.
I already have a RGB controller that could be used presumably placing the PWM dimmer on the output side of the RGB controller?
I'm fairly new to electronics but have a good electrical background. I intend to build it on a vero or similar.
If my current RGB controller cant be used then I have found a 555 circuit on this board that I'll use.
Thanks for your input guys
