3 caps RC
Discussion in 'General Electronics Chat' started by DexterMccoy, Apr 13, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    Why did they use 3 caps, C1,C2,C3 with R1 100 ohm
    Why 3 caps with R1 for an RC timing network?
    The RC timing network is in parallel with A1 module board
    here is the schematic
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,701
    1,299
    Because 580 uF is not an industry standard value.
    ak
  3. DexterMccoy
    Feb 19, 2014
    429
    Is it for another reason to put 3 caps in parallel with one resistor to make an RC network?
  4. shortbus
    Sep 30, 2009
    4,096
    1,692
    Another question that only the designer of the circuit would know. Some day you will learn that a designer/engineer does what they do because that is the way they do it. There is no "name" for it.
  5. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Use three caps: Reasons
    (1) gives the required capacitance for the design
    (2) Cheapest available components available in quantity at the time
    (3) Thats what was in the makers store at the time.
  6. DexterMccoy
    Feb 19, 2014
    429
    Does adding 3 caps, Triple the storage , so it stores the voltage better VS having One cap do it?
    having 3 caps, with 3 different cap values, is 3 different phase angles
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Again, really basic questions, things taught in 1st year 3rd week tech school.
    Caps in parallel are additive, and their highest voltage is what ever the weakest link is. In other words, the cap with the lowest voltage rating.
  8. BillB3857
    Feb 28, 2009
    2,402
    348
    No, the three shown would have the same effect as a single with the value of the sum of the three.
  9. DexterMccoy
    Feb 19, 2014
    429
    so it's all about getting that capacitance value when you add 3 caps together?
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Mostly. There is also an issue of frequency response of capacitors. If this were a power supply filter they may use the large electrolytic caps to take care of 60 cycle hum and smaller caps to take care of faster transients.
  11. DexterMccoy
    Feb 19, 2014
    429
    Now the fast transients come from the 60 cycles?
  12. BillB3857
    Feb 28, 2009
    2,402
    348
    Faster transients can come from sudden changes in the load current.
  13. DexterMccoy
    Feb 19, 2014
    429
    So the power supplies load?, can have fast transients from the load current
    So you're saying that the power supplies load can "reflect" fast transients into the power rails?
  14. Wendy
    Mar 24, 2008
    20,772
    2,540
    Digital logic, which you have asked many questions about, create fast transients. So do light switches, or relays or any number of other things. Ultimately everything ends up in the power supply rails.
  15. DexterMccoy
    Feb 19, 2014
    429
    Well they use decoupling caps to filter out the fast transients
    These transients are overshoot voltages and undershoot voltage
  16. Wendy
    Mar 24, 2008
    20,772
    2,540
    You persist in ignoring the obvious. Bypass caps are in parallel with the power supply caps. They are part of the total capacitance, just like the example you gave when asking the question.
  17. DexterMccoy
    Feb 19, 2014
    429
    The Transients are caused by the voltage and current potential difference being shunted or shorted out to ground without any draining off or transient protection
    Relays have a parallel diode
    Switches have a parallel capacitor
    This helps CLAMP the voltage and current on the transient
  18. Wendy
    Mar 24, 2008
    20,772
    2,540
    Not always. Electronics is rarely about absolutes. Clamping diode have switching speeds, for example. And the act of contacts causing a current draw can cause transients. A 100W light bulb draws almost an amp, which going to show up on the mains.
    You said it yourself, it helps. It is not perfect.
    Batteries also have internal resistances which help contribute.
  19. ian field
    Oct 27, 2012
    4,456
    792
    Electrolytics in parallel also give a lower net ESR than a single cap - but that's hardly likely to be the issue with a 100R resistor in series with the parallel combination.
  20. DexterMccoy
    Feb 19, 2014
    429
    But that's good to have a low ESR? Right
Thread Status:
