Have you tried simulating it?My assignment is design a 3 bit up/down counter using positive edge triggering clock pulses with T-flip flop.Is this correct??
Is it right or wringMy assignment is design a 3 bit up/down counter using positive edge triggering clock pulses with T-flip flop.Is this correct??
Walk through it and figure it out. It should only take a few minutes to build up the transition tables to verify whether it works correctly or not. If you run into problems, post what you've done so far and we can help you figure out how to move forward.Is it right or wring
This thread is old and the original poster hasn't been on the forum for 6 years.Is it right or wring
by Duane Benson
by Jake Hertz
by Aaron Carman
