3 bit down counter
Discussion in 'Homework Help' started by chillyster, Jan 30, 2012.
  1. chillyster
    Jan 30, 2012
    can anyone help me design a 3-bit down counter that counts from 7 to 0? and when the counter reaches 0 an Led should light up to indicate that it reached 0. The inputs consist of Start/Stop pulse switch, a Preset pulse switch and a Clock Input. The output should be connected to the LEDs.
  2. Georacer
    Nov 25, 2009
    5,151
    1,266
  3. chillyster
    Jan 30, 2012
    damn i dun understnd :(
  4. holnis
    Member
    Nov 25, 2011
    50
    I believe there is enough informations in the links above. Anyway Counting down rather than up simply requires cascading the clocks using the inverted outputs.
    Check the attached description, it's an MOD-8 asynchronous down counter that counts from 7 to 0:
  5. MrChips
    Oct 2, 2009
    12,652
    3,461
    You can use an off-the-shelf down-counter or you can build it with flip-flops using Karnaugh maps.
