3 bit counter mmlogic?
Discussion in 'Homework Help' started by pauljoost, Sep 26, 2010.
  1. pauljoost
    Sep 26, 2010
    can someone make this for me? im stuck and i don't know how to.
    i'll post an example of a 2 bit counter:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Take a look at the data sheet for a 7493.
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Isn't 7493 a counter? What does a counter have to do with the above design?
    Unless this circuit does someting standard, which I don't see at the time, you could use 2 IC's to build it. One 7486 for the 4 XOR's and one 7400 for the AND's.
    It would be nice if someone would recomend a series other than 74XX too.
  4. WINPINPH1
    Sep 27, 2010
    24
    you need to make a table to solve that problem. be familiar with logic gates you'll be fine.
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    First of all, let me correct my previous post. I see now that the circuit is a 2-bit counter, but not the type of the 7493, which is a flip-flop counter. It is a carry-out prediction, no-carry-in counter.
    But what does the OP want to do with this? Do you want a truth table? A way to build it on a board? A description of its function? Please be more descriptive.
