3 bit comparator
Discussion in 'Computing and Networks' started by Manya1991, Dec 12, 2012.
  1. Manya1991
    Dec 12, 2012
    How to design a 3 bit comparator ADC in which the output is in excess-3 representation?
  2. WBahn
    Mar 31, 2012
    18,085
    4,917
    Is this homework? If so, then it should have been posted in the Homework Help forum (but don't move it, a moderator can do that if needed).
    What do you mean by a "comparator ADC"? I think I know what you have in mind, but not sure.
    What steps have you taken to attempt to solve the problem?
    First off, do you even understand what it is you are trying to achieve? Imagine your solution is sitting in a black box. What would the inputs and outputs be and can you very clearly describe the relationship between them?
