Yes, you need the push-pull transistor circuit at the output (without the 100k resistors) to provide additional current to drive the speaker.
With a +/- 15 volt supply The 741 itself can only supply around 5 or 6 ma into a 2k ohm or greater load which equates to 10 to 12 volt swing. But as the load resistance drops so does the voltage swing.
What would the voltage be across an 8 ohm load with 5ma's of current?
If you added transistors with a gain of 20, what would the current and output voltage be for an 8 ohm load?
EDIT: Also, as frequency increases the output of the op-amp may decrease. (Look up gain-bandwidth product).
The 500 ohm load was high enough to allow a reduced but useful output signal.
BTW. Have you tried the circuit without the 100k resistors ?
