3-8 decoder with 2 2-4 decoder
Discussion in 'Homework Help' started by Leite33, Dec 6, 2015.
  1. Leite33
    Nov 28, 2015
    57
    Dear friends.
    I looked a lot at google but i cant find a solution. How i can make one 3-8 decoder with (2) 2-4 decoders with out use enable input and without inverse outputs.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    You will NEED the select or enable inputs for making a 3->8 using 2 X 2->4 decoders.
    Bertus
  3. Leite33
    Nov 28, 2015
    57
    But my exercise says "Design a circuit that will produce a digit of even parity for a number of 3 binary digit (xyz) using:
    a) decoder 2-4 (without using enable input and inverse outputs) and gates OR
  4. WBahn
    Mar 31, 2012
    18,080
    4,917
    In other words, the problem is NOT asking you to create a 3-to-8 decoder at all!
    How would you make an even parity generator for a three-bit input using XOR or XNOR gates?
    How would you make an XOR of XNOR gate using 2-4 decoders and OR gates?
  5. Leite33
    Nov 28, 2015
    57
    So you say to me that exercise is wrong?
  6. WBahn
    Mar 31, 2012
    18,080
    4,917
    There is nothing wrong with the exercise as you presented it in Post #3:
    But this is NOT the same problem that you described in your original post:
    These are two essentially unrelated problems. The only thing they happen to share is that each involves 2-4 decoders.
    Which problem are you trying to solve?
  7. Leite33
    Nov 28, 2015
    57
    Sorry the first one.
  8. WBahn
    Mar 31, 2012
    18,080
    4,917
    Which brings us back to my previous question, but let's rephrase it a bit.
    Produce a circuit that produces an even-parity output for a three-bit input using nothing but XOR and XNOR gates.
    Do that much first, and then we can worry about using 2-4 decoders and OR gates.
  9. WBahn
    Mar 31, 2012
    18,080
    4,917
    Actually, you don't. You can use a 2->4 decoder (without enable) to produce an AND gate and to produce a NOT gate. That means that it is a universal gate and that you can implement ANY Boolean function using just a bunch of 2-> decoders. Now, it may not be pretty, but it can be done.
