David Pate
- Joined Oct 29, 2013
- 25
That is not strictly correct. The battery capacity is probably rated on a 20 hour draw. If you draw 10 times faster (2 hours) the capacity must be substantially derated. Off the top of my head I would guess the capacity may drop to 75% or less; thus only a 1.5 hour run-time.The capacity of the battery is listed as 1000 mAh (milliamp-hours). So any combination of of current flow and time multiplied together should yield 1000.
