3.6 volts to 2.4 volts
Discussion in 'The Projects Forum' started by silii, Mar 29, 2008.
  1. silii
    Mar 29, 2008
    hi
    i have a handspring pda that runs on two AAA cells (total volts 2.4 volts).
    i am fed up with using rechargeable cells , i have 3.6 volts lithium ion battery with the charger (those used in cell phones).
    i want to use the 3.6 volts li-ion cell in my pda, how can i reduce the 3.6 volts to the required 2.4 volts-thanks
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I would suggest a low dropout voltage regulator.
  3. HarveyH42
    Jul 22, 2007
    425
    5
    Doesn't a diode drop .6 volts, so two in series would be 1.2 volts. Your PDA might handle the 3.6 volts just fine as is though. New pair AA batteries are more then 3.0 volts... Should be some regulation built in to the PDA.
  4. E.E.
    Apr 2, 2008
    8
    For voltage regulation, there are some transistor circuits you could check out. Just a line from the battery to the transistor and ground etc. Its pretty easy, and if you wanna do that just shoot me a PM, I can help. :)
