I am currently working on a voltage regulator design for my project at university. We have not learn anything about transistor and I am somewhat no sure about my idea, so I try to find some help here.
Specifications for the regulator are listed below:
Input power source: A lab power source of 36V and 4A max, I need a voltage input around >=28V
Output is desired to be 15V(adjustable through the adjustable voltage regulator) and can hold up to 3.5A.
Use university parts are preferred since they are free and may get bonus for using only school-provided parts.
Parts used and parts that are available at school:
The motor is a dc motor. We used it for the previous project at 7.5V and >1A. However, we try to double the speed by boosting the motor voltage to 15V. The motor's stopping current is around 3.2A.
Q1 is a PNP. Transistors that are available at school are:
2N3906BU
2N3904BU
2N6426G
The trimmer(variable resistor) is PV36Y103C01B00, and we have PV36Y102C01B00,PV36Y104C01B00 at school.
The adjustable voltage regulator is LM317.
Other parts that our school can provide can be found in the following link:https://docs.google.com/spreadsheet/ccc?key=0AjpsGmmb_spEdHhnMFJqQTNzc3lSQUR3V0ZtUzlKMVE
Problem occurred:
The transistors at school can not hold more than 200mA, which means I need to parallel the transistors or come up with a new design.
I want to know which is more feasible, using parallel transistors(if so, is there anything I need to pay attention to, cause some threads talked about resistors for the parallel transistors), or come up with another design.
Note:
If you find anything on the schematic that can potentially be a problem, please feel free to say it.
You help is very much appreciated and thank you for taking time to read this long text.
This design is not originally my idea, I combined two circuits found in the LM317 and 78XX voltage regulator's datasheet, and thanks to those guys' work.
Best wishes
Eric
Enclosure: Schematic of the voltage regulator
2N3906BU
2N3904BU
2N6426G
Problem occurred:
Note:
Best wishes
Eric
