3.5, 4.5, 5.5, 6 volts power pack powered by 12v battery
Discussion in 'The Projects Forum' started by cedelive, Jan 27, 2011.
  1. cedelive
    Mar 10, 2009
    i need a power pack that has 3.5, 4.5, 5.5, 6.5 volts(dc)
    ranges that will be powered by a 12 volts dc power
    i will appreciate if the circuit diagram is included
  2. Ctenom
    Member
    Nov 1, 2010
    59
    Whats the expected current draw? a rotary switch and some voltage regulators should do the trick if you want to keep it simple.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    This crys out for a switching power supply, since a good design there will use minimum juice and create very little heat. 3V at 1A would be 12V @ 300ma at the battery.
  4. cedelive
    Mar 10, 2009
    the input current is .92A/12v
    while the out put is between 300mA and 500mA
  5. cedelive
    Mar 10, 2009
    input current is 0.92A while that of output is between 300mA to 500mA
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    I'm currently playing with SMPS regulators. In 6 months I may have something I could recommend.
    On the short term though...
    Properly heatsinked, the LM317 can handle 1 amp. The TO3 case style can handle 1.5A. It will get hot, very hot.
    You can use a series of resistors with switches across them to select voltages. Since you have 1V steps it should be easy.
