3.3V -> 1.8V level shifter
bumclouds
Joined May 18, 2008
81
Hi everyone,
I'm trying to connect a device which uses 3.3V logic to the input pins of a microprocessor that can only tolerate 1.8V.
So I need to step down the signal from 3.3V to 1.8V.
Can anyone on this forum recommend a common and easy to find IC which does this job? DIP package is the only option for me here.
Thankyou!
- Andrew
kubeek
Joined Sep 20, 2005
5,795
What speed are we talking? A simple resistive divider should do the job for the 3.3->1.8v conversion. The other way, most devices nowadays accept anything greater than 0.8V as a logical 1, so you should be safe there, but check the datasheet.
34,464
Not quite. The maximum logic 0 it often 0.8V or less but the minimum logic 1 is usually at least 2-3V. The voltage in between those two levels is a no-man's-land where the circuit may interpret it as either a 1 or a 0 depending upon the particular circuit tolerances.
But that still means that a 3.3 logic high will be correctly interpreted as a logic 1 by 5V logic.
kubeek
Joined Sep 20, 2005
5,795
You're right, I misinterpreted the datasheet I was reading, the actual thresholds for 3.3Vcc were <0.6V for 0 and >2V for 1.
steinar96
Joined Apr 18, 2009
239
A resistive divider may cause problems due to either too high input resistance (if its too stiff) or waste of power (too soft). There are many other ways to translate while maintaining proper conditions at the IO pins. These include diode clamping circuits.
bumclouds
Joined May 18, 2008
81
The device I am using is a PSX game controller which (i think) has a baud rate of 9600kbps.
The device I am using to read from the game controller is a Texas Instruments microprocessor whose input pins are not 3V tolerant (confirmed on the TI forums).
Will using a simple resistor divider for each pin do the trick?
