2x16 LCD Display PCB
Discussion in 'Marketplace' started by joeyd999, Dec 7, 2011.
Thread Status:
Not open for further replies.
  1. joeyd999
    Thread Starter AAC Fanatic!
    Jun 6, 2011
    2,759
    2,943
    I've got a quantity of custom 2x16 LCD display PCBs that were for a customer who has hit hard financial times. I'd like to get rid of them.
    I have 2 versions of the PCB, one with a PIC18F2321, and one with a PIC18F2420.
    The display has a blue backlight (always on, but configurable for either software control for on/off or PWM driven for varying intensity).
    There are 3 miniature push button switches on the PCB, tied to RB4, RB5, and RB6.
    There are provisions on the PCB for 4 LEDs (not mounted), each under software control with PWM capability for brightness.
    A 6 pin RJ45 footprint is included to attach the PCB to an ICD2 for programming and/or debugging. The connector is not included, but is available from Digikey.
    The are two miniature connectors on the board: a 4 pin connector that supplies power and supports EUSART communication (TX/RX only, no hardware handshaking). Also, a 3 pin connector that provides regulated 5VDC from the PCB and makes a connection available to RB2/INT2.
    RB3 is connected to an on board test point.
    The boards are about 4.4" x 2.5" x 0.75", and the LCD stands off the surface to about 1/2" total height. There are 4 mounting holes in the corners for #6 screws.
    User must provide power between 8 and 12V. The current requirements are minimal, except for the LCD backlight.
    No programming will be included, but I will provide schematics, and I can help through this forum (I do not have the time to provide individual private help).
    I can the let boards go for $40 each (with the PIC18F2321) or $45 (with the PIC18F2420). Supplies are limited, first come first served. I don't have all stock here at my location, so I can advise when material would be available.
    The PCBs are 100% functionally tested.
    I can supply photos, if someone tells me how.
    Any interest?
  2. joeyd999
    Jun 6, 2011
    2,759
    2,943
    Here are the photos (hope this works!)
  3. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Yikes $45! A $6 display and $4-$5 PIC. Excellent work on the PCB so that is probably worth something, the connectors are a nice feature but most folks here can make their own. Plus it is a lot more fun to build your own So don't be surprised if you don't find any takers.
  4. spinnaker
    Oct 29, 2009
    5,115
    1,195
  5. joeyd999
    Jun 6, 2011
    2,759
    2,943
    These are boards I've got laying around...doing nothing. I just thought I'd make the offer in case anyone wanted a quick display solution. The LCD is 2x16 with a backlight, dissimilar to the link you provided.
    FYI, I'm not really here to sell anything. I just made the offer because I thought there might be interest.
    I would entertain counter-offers.
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    Doesn't look like all I/O is accessible, such as PORTC (LCD), PortB, PortA, I suppose they can be reached with careful soldering of wire-wrap wire on the pins.
    The onboard regulator is nice, so is the LCD connector, and I understand the cost of short run PCBs, but $40 is a bit steep for what usable lines are available.
    Do you haggle?
  7. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Actually very similar if not more capable. I looked at my link again and it does seems to only be a normal LCD and not graphic.
    It is similar to yours except the one in my link does not have a backlight. Which is sometimes good and sometimes bad.
    You might want to consider a pricepoint somewhere between $15-$20.
  8. joeyd999
    Jun 6, 2011
    2,759
    2,943
    Yes, as I said, I will entertain offers. I've got about 150 of these boards...quantity helps!
    FYI, this PCB was designed to be a display/controller PCB for a master PCB that connected to it via the serial lines. It is what it is...and it works very well. There are about 500 of these in the field.
  9. spinnaker
    Oct 29, 2009
    5,115
    1,195
    The connector for the LCD looks very interesting. Nice low profile. Do you happen to know the type of connector?
  10. joeyd999
    Jun 6, 2011
    2,759
    2,943
    J103 Conn, Header, 4POS, R/A 2mm Tin JST S04B-PASK-2(LF)(SN) Digikey 455-1849-ND
    J104 Conn, Header, 3POS, R/A 2mm Tin JST S03B-PASK-2(LF)(SN) Digikey 455-1848-ND
  11. spinnaker
    Oct 29, 2009
    5,115
    1,195
    Thanks but I meant the 16 position one for the LCD.
  12. joeyd999
    Jun 6, 2011
    2,759
    2,943
    J102 Conn, Receptical, 16POS, Tin 0 Hirose MDF7-16S-2.54DSA(55) Digikey H10665-ND
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    The Voltage regulator on board.
    What is the current capability of it, and is the PIC running at 5V or 3.3V?
  14. joeyd999
    Jun 6, 2011
    2,759
    2,943
    U103 IC, Volt Reg, 5V 100mA 8-SOIC Natiional Semi LM78L05ACMX/NOPB Digikey LM78L05ACMXCT-ND
    Pic runs 5V.
Thread Status:
