2W Regulated Power Supply
Discussion in 'The Projects Forum' started by washer, Jun 22, 2012.
What is the easiest/cheapest/fastest 2W supply design with a 277Vrms in and 3V3 out?
Poll closed Jun 29, 2012.
  1. Capacitive, Rectified, Regulated
    0 vote(s)
    0.0%
  2. Resistive, Rectified, Regulated
    0 vote(s)
    0.0%
  3. Linear Transformer, Rectified, Regulated
    0 vote(s)
    0.0%
  4. SMPS (Flyback?)
    0 vote(s)
    0.0%
  5. None of the above!
    0 vote(s)
    0.0%
Thread Status:
Not open for further replies.
  1. washer
    Nov 25, 2009
    10
    Hi all,
    It's been a while since I've posted but I've been lurking around.
    I'm working on a 2W power supply with a 277Vrms (line-to-neutral) source and a 3.3Vdc output with a max current draw of around 200mA.
    Since our requirements are pretty meager requirements, I've been looking at a resistive or capacitive supply similar to the ones discussed in this <SNIP>. I simulated the rectified resistive supply in LTspice and found out (more from trial and error with load resistors than the equations in the note) that it can't support a load of more than 50mA. I've attached two pictures of my simulation with a 16Ω load failing the ckt, and a 70Ω load showing proper operation.
    I can follow the math in the note, but am a little confused as to which equations apply to which topologies and how I can find out what the capacity of the supply is.
    Can anyone help explain what is the bottle neck in this supply? Is there a way to pull 200mA from a resistive or capacitive supply? If not, what would be the next easiest/cheapest/fastest design?
    I haven't found many step down transformers that I could use for a linear supply, but maybe I haven't been searching well enough. I've also started to look into some Flyback and other SMPS designs, but was getting pretty confused and would really like to get a "good enough" design working while I try to learn about a more efficient SMPS design. If anyone has any advice/references for a SMPS, I'd love to hear that as well!
    So is there any way to pull 200mA from this type of cheap supply?
    Thanks for any help!
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    Better look for linear powersuplies with a transformer or SMPS powersuplies.
    For SMPS you can look here: SMPS
    For linear powersupplies you can look here: Power supplies
    Bertus
Thread Status:
