2nd order passive RC filter Transer Function
Discussion in 'Homework Help' started by VVS, Dec 17, 2008.
  1. VVS
    Thread Starter Active Member
    Jul 22, 2007
    66
    Hi I need to derive the Transfer Function for the circuit i have attached. I am just not able to get there. I am almost there, but i think I have done something wrong and I just cannot find what is wrong.
    Can some1 pls show me the full working. I have done it with help of Thevenin Equivalents. But as i said cannot get the correct function.
    pls help me
    btw: tau1=R1*C1 tau2=R2*C2 tau12=R1*C2 and assume that R1=R3
      File size:
      16.3 KB
      103
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    It would be good if you can post your solution. That way we can assist you in identifying where you took a wrong turn in your effort.
    hgmjr
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    After working through the calculations, I was able to duplicate the answer contained in your attachment with one exception. The answer I arrived at does not contain the quantity -1 in the denominator. In my answer, the corresponding value is +1. In all other respects, the answer I have calculated matches the one given in the attachment term for term.
    I hope you will be able to post your work soon so that we can try to spot where you may be having a problem with your calculation.
    hgmjr
