2nd order low pass filter
Discussion in 'Homework Help' started by The_Cook, Jun 1, 2014.
  1. The_Cook
    May 29, 2014
    48
    Could anyone help me find the transfer function of the 2nd order low pass filter and prove the variables are true as shown in the question?
    Any help is appreciated
  2. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,699
    1,298
  3. The_Cook
    May 29, 2014
    48
    Would you mind explaining what a unity gain is, and if that applies to the circuit I posted.
  4. shteii01
    Feb 19, 2010
    3,505
    512
    Unity Gain is Gain=1=Av.
    Since your Av is Av=Rb/Ra, make Rb=Ra, then Av=1 and you meet the unity gain definition of Gain=1=Av.
  5. The_Cook
    May 29, 2014
    48
    What does s stand for in the equation?
  6. shteii01
    Feb 19, 2010
    3,505
    512
    s=jw
    From wiki:
    "The transfer function can also be shown using the Fourier transform which is only a special case of the bilateral Laplace transform for the case where s = j\omega."
    http://en.wikipedia.org/wiki/Transfer_function
    The_Cook likes this.
  7. AnalogKid
    Aug 1, 2013
    4,699
    1,298
    If you don't know what s and unity gain are, how is it that you have a problem regarding transfer functions? The transfer function of a multi-pole filter is pretty advanced math, requiring an understanding of several layers of underlying concepts including complex algebra (imaginary numbers). I'm not criticizing you, just observing that you might be out of your depth.
    ak
  8. The_Cook
    May 29, 2014
    48
    Do you just write the transfer function in terms of the variables since they don't have any values given in the question or am I missing something?
  9. shteii01
    Feb 19, 2010
    3,505
    512
    No, you are not missing anything. For Part a you just write transfer function in terms of R1, R2, C1, C2, Ra, Rb. That is exactly what Part a asks you to do.
  10. Jony130
    Feb 17, 2009
    3,993
    1,116
    Yes, for example
    (Vs - Va)/R1 = (Va - Vp)/R2 + (Va - Vout)*s*C1
    (Va - Vp)/R2 = Va*s*C2
    Vout = Vp * Av
    Where Av = 1 + Rb/Ra
    And you solve this for Vout/Vs
  11. The_Cook
    May 29, 2014
    48
    The design given on the wikipedia article does not have Ra and Rb, would you happen to have an example similar to my design circuit
    Found this example:
    http://www.daycounter.com/Filters/SallenKeyLP/Sallen-Key-LP-Filter-Design-Equations.phtml
    How would you factor in the Rb and Ra into that equation, which isn't in the example circuit but in my question
