2nd ODE with initial conditions
Discussion in 'Math' started by squirby, Aug 24, 2009.
  1. squirby
    Aug 21, 2009
    15
    hey guys.
    wondering if anyone can explain how they got to this stage:
    y''(t) + 2y'(t) + 5y(t) = 0 , Initial conditions: y(0) = 2, y'(0) = -4
    Answer:
    y(t) = [√5 exp(-t) cos{ 2t + pi - arctan(1/2)]
    when i work it out, i get
    y(t) = exp(-t) [2cos2t - 2sin2t]
    any help is much appreciated.
  2. Mark44
    Nov 26, 2007
    626
    Your answer looks correct to me, and the other answer looks incorrect. It's very easy to check whether your answer is correct, though. If it satisfies the initial conditions and differential equation, it is correct. If the other answer doesn't satisfy the initial conditions and differential equation, it is correct.
    For the differential equation, the solution must be y = c_1e^{-t}cos(2t)+ c_2e^{-t}sin(2t)
    for some constants c_1~and~c_2.
    The constants are determined by the initial conditions y(0) and y'(0).
  3. squirby
    Aug 21, 2009
    15
    hey guys. i finally figured out why the answer was
    y(t) = [√5 exp(-t) cos{ 2t + pi - arctan(1/2)].
    this answer is correct, and my initial answer was incorrect.
    the correct answer should have been
    y(t) = exp(-t) [2cos2t - sin2t]. while this is correct, it can also be expressed in the form above.
    as you know, when an solution to a differential equation has imaginary roots, it can be expressed as:
    y(t) = exp(At)[CcosMt + D sinMt] where the roots of the solution to the differential equation is A ± Mj where j is the imaginary number √-1 and A and M are real numbers.
    however, y(t) can also be expressed in another fashion:
    y(t) = [√(C^2 + D^2)]exp(At)cos[Mt - arctan (D/C)].
    applying this to y(t) = exp(-t) [2cos2t - sin2t] you arrive at y(t) = [√5 exp(-t) cos{ 2t + pi - arctan(1/2)]. this is a rule apparently, although I have never seen it in any textbook. my electrical tutor told me about it.
    anyways just thought i'd share the info wif u guys.
  4. volume
    Sep 7, 2009
    to be in save side i use Maple program :)
  5. ][ Shocked ][
    Member
    Apr 13, 2009
    22
    it got to be easy !
