2N3819 Pinout ?
Discussion in 'General Electronics Chat' started by bannerman, May 26, 2012.
  1. bannerman
    May 25, 2012
    A similar question to this was asked a few years ago, but without getting the reply that I need.
    Can someone please post a method of experimentally determining the pinout of the 2N3819 ? (Or even JFETs generally ?)
    I just feel better if I can check it myself first, rather than blow the thing up, as in one place I read that incorrect connection can destroy a JFET.
  2. Ron H
    Apr 14, 2005
    I'm fond of datasheets. but you can use an ohmmeter. Move the leads around until you get a diode indication. If you don't know what that looks like, try it on a diode first.
    For an N-channel JFET, the red lead will be on the gate, and the black lead will be on the source or drain. Source and drain are interchangeable on almost all JFETs.
    A P-channel will be the same, but with the leads swapped.
