2n2222 Transistor Radio from white noise generator. problem with grounding.
Discussion in 'The Projects Forum' started by MarFene, Aug 5, 2015.
  1. MarFene
    Feb 27, 2014
    39
    I was trying to build a white noise generator i found online consisting of two 2n2222 transistors. after finishing the schematic ,which resulted in a non working circuit , i touched the log of a capacitor which immediately gave a strong signal on the output. after messing around a littile i realised that with an antenna i had in hand a tuned radio frequency receiver tuned on around 93.7~~ MHz
    The only problem is that when i modified the circuit as i am showing in red in the schematic attached , the signal was not constant and i had to touch the inductor with one hand the and antenna with the other hand.
    can anyone guide me ?
    the vide below should also help in my explenation.
  2. #12
    Nov 30, 2010
    16,705
    7,358
    Sit on a chair and get your feet up off the floor to make yourself a better antenna. Wet both fingers slightly for better contact.
    ronv likes this.
  3. MarFene
    Feb 27, 2014
    39
    i would like to eliminate the fact of having to touch the antenna
