2K res to ground
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 14, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    Is using a 2k ohm resistor to ground , to short output the inputs of Op amps ok to do when troubleshooting?
    The 2K ohm resistor is used to protect and to limit the "In rush current" when doing a short to ground
    Is 2K ohms enough for the in rush current and to protect when shorting out Nodes or junctions in a circuit? shorting out inputs to transistors and op amps?
  2. DexterMccoy
    Feb 19, 2014
    429
    The outputs in Idle mode when there is No input signal should be at 0.030 VDC , this is millivolts
    What I am getting is 0.060 , 0.080 vdc
    How can I find this type of problem , because I'm troubleshooting millivolts when their is no input signal, when the transistors and op amp is in idle mode
    How would you guys try to troubleshoot when the voltages are in millivolts when there is no input signals , the transistors and Op amps are in idle mode which means no input signal
    It's the DC voltages and noise it's on the outputs of transistors and op amps
    Here is the schematics
  3. DexterMccoy
    Feb 19, 2014
    429
    another schematic
  4. DexterMccoy
    Feb 19, 2014
    429
    What is it called when the transistors and op amps have No input signal but the outputs of the transistors and op amps output millivolts voltages?
  5. GopherT
    Nov 23, 2012
    6,330
    4,070
    Input offset voltage?
    A bad design?
    A ...?
  6. shteii01
    Feb 19, 2010
    3,516
    515
    Offset or noise.
    If it is flat voltage, I would say offset.
  7. DexterMccoy
    Feb 19, 2014
    429
    But can I use a jumper wire with a 2k ohm resistor to ground to short out the inputs to transistors and op amps? Is this safe?
  8. shteii01
    Feb 19, 2010
    3,516
    515
    Depends on application.
  9. DexterMccoy
    Feb 19, 2014
    429
    Depends on what? The current and voltage rating? Is 2K safe or shouldI use 1meg ?
Thread Status:
