I would definitely not recommend you do anything like that for an aircraft. Failure is not an option when you are doing modifications to an aircraft. And I'm sure the FAA would not approve either.The voltage regulator is external to the alternator.
The 12v power is for an aircraft.
Thanks for responding!
