28v AC bulb tester
Discussion in 'The Projects Forum' started by adamcswant, Apr 19, 2012.
  1. adamcswant
    Mar 23, 2011
    34
    So I need to build a bulb tester for testing Eiko 1820 bulbs. They require 28v AC, 0.1A and consume about 3W. Any ideas on how I can do this?
  2. P-MONKE
    Member
    Mar 14, 2012
    83
    5
    Just use a continuity meter, surely?
    Or are you wanting to test how bright they will be? In which case, get yourself a 28V ac power supply and a bulb holder!
  3. gerty
    Aug 30, 2007
    1,154
    304
    All you really need is a 120 to 28 volt step down transformer
  4. adamcswant
    Mar 23, 2011
    34
    I definitely need to check them at 28V so that I can confirm their brightness. I've done some searching for a step down transformer... but I can't seem to find a match. Any links to some good sites that would carry one?
  5. wayneh
    Sep 9, 2010
    12,381
    3,236
    Are you planning on just eyeballing the brightness level? Unless you do side-by-side against a reference, it could be tough to make a judgement.
  6. #12
    Nov 30, 2010
    16,679
    7,322
  7. mcgyvr
    Oct 15, 2009
    4,789
    974
