28 volt buffer?
Discussion in 'General Electronics Chat' started by chris13409, Feb 2, 2010.
  1. chris13409
    Jan 7, 2010
    7
    What device do I need? I need to buffer some logic levels so they can be sent to a PIC. They vary between 7 to 28 vdc. Is there a buffer that can tollerate 28vdc while drawing very little current The output voltage from the buffer can be anything from 1 to 5 vdc.
  2. mik3
    Feb 4, 2008
    4,846
    63
    You can use an op amp voltage follower with the signal fed to its input. If you want to reduce the output voltage use a voltage divider.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    What kind of tolerance do you have on the translator current?
    You might use a resistive divider and a comparator.
  4. Bernard
    Aug 7, 2008
    4,240
    414
    Look at MM74C914, schmitt trigger with extended input voltage. Might be close.
  5. rjenkins
    Nov 6, 2005
    1,015
    69
    For logic inputs, a simple resistive divider will work fine.
    Three resistors connected to a junction point; 2k2 from the input, 4k7 to ground(0V) and 100K to the PIC input pin.
  6. chris13409
    Jan 7, 2010
    7
    Thanks guys,
    I think the MM74C914 might do it. These are fault signals, and I usually check them with a multimeter. (I should have said that in the first place.)
    I'm not sure I can use a voltage divider because it'll draw too much current from my system.
    Chris
