277 volt light on 120 volt line
Discussion in 'General Electronics Chat' started by JM9920120, Oct 5, 2007.
  1. JM9920120
    Oct 5, 2007
    Can I connect a 277 volt light with a transformer to a 120 volt that runs other lights or do I have to run its own line
  2. ixisuprflyixi
    Sep 16, 2007
    52
    please do not try to hijack other peoples threads.
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Is your transformer a 120vac to 277vac transformer? If it is, then go ahead. Make certain your connections are correct. If the transformer is not 120 to 277, then you're out of luck.
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    You can run the transformer in the same line where you have the other lights. No problem. The concept of line is a faulty one. After all, all the lights end up to be in parallel, right?
  5. recca02
    Apr 2, 2007
    1,211
    the only problem is to find a transformer with the desired ratings,
    go for a 120/277 volts transformer which can handle the min reqd power.
