Not sure if this is the correct place for this or not, but I am trying to fix a salt generator in my pool, I changed the main circuit board, but two compents burned. The diagnostics states if you measure at both hot leads you should be between 209 and 241, but I am measuring 253. I am curious if this is cause for concern and if so, what I should do to remedy this.
