250v 7.5amp 1875watt Transformer or Power Supply
Discussion in 'The Projects Forum' started by Johnno123, Jan 11, 2016.
  1. Johnno123
    Jan 11, 2016
    5
    hi, i really want to know if a transformer or power supply of 250v 7.5a can run a pedestal fan. I checked the plug for the power outlet and it says 250v 7.5a. is this right? i just want to power the fan without the power outlet. if this is right could anyone tell me where i can purchase a power supply or transformer and if i can go to 10 amps instead of 7.5. Ive been searching but have not found anything suitable. thanks :)
  2. Dodgydave
    Jun 22, 2012
    5,172
    779
    What is the voltage and current rating of the fan?
  3. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Welcome to AAC!
    So what will power the transformer?
  4. Johnno123
    Jan 11, 2016
    5
    inside with the motor is says 18 motor 220v-240v 50hz 65 watts. and I would like to use a very small power input for the transformer if that is possible.
  5. Dodgydave
    Jun 22, 2012
    5,172
    779
    So if the fan motor is 65W at 230V, thats less than 0.5amps, yes your transformer will work.
  6. Kermit2
    Feb 5, 2010
    3,858
    968
    It is a very small motor. The term used to describe such is fractional HP motors. The one in question is around 1/10 to 1/12 HP.
    You could run it easily at 30 to 50% of rated voltage, BUT you might have to give the fan blades a push to get it to started.
  7. Johnno123
    Jan 11, 2016
    5
    nah id rather by a transformer that is around the same input as the power outlet. does anyone have any idea where I could buy such a specific transformer? thanks
  8. Kermit2
    Feb 5, 2010
    3,858
    968
    The motor is a fractional horsepower motor.
    It is a 220 volt motor, Europe style 50 Hz from your description.
    It WILL WORK acceptably on standard US 120 volt 60 Hz as well. It just moves air. This isn't an industrial motor so 7.5 amp power supplies aren't need. You need half of 1 single amp of alternating current from a plug to make the fan work.
  9. Johnno123
    Jan 11, 2016
    5
    thanks for tell me. do u have any recommendation on where to buy the transformer?
  10. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You really don't need that just to power the fan, as others have indicated, but if you're determined to get a tranny with that rating how about something like this? That's a mighty expensive fan driver :).
  11. Johnno123
    Jan 11, 2016
    5
    ah man, haha well thanks for all your help :).
