You are better off going with 74HC devices.I plan to order a selection of CMOS logic ic's for experimentation. I don't have a specific project in mind, and plan to spend about $25, which looks like it will buy about 50 pieces. What should I buy and how many of each one?
Thanks.
You can actually make all of those gates using either diodes and or transistors.I
(5) 2-INPUT AND
(5) 2-INPUT NAND
(5) 2-INPUT OR
(5) 2-INPUT NOR
(5) HEX INVERTERS
So cheap now in fact that, I think that in the case that one is required -- you can just emulate the chip in software.PS: With the advent of low cost, low pin count MCUs, the need for digital logic chips has been reduced substantially. I would highly recommend learning to program MCUs if you have not yet done so.
Emulating those in software on a PIC is dead easy. So, you will always be able to get them.4017, 4026, 4013, etc.
You misunderstand me friend. I mean an actual REAL drop in replacement.I don't use a simulator.
Is that right? Geez.We are not too far from fabricating chips on the home level with several different methods. The one I'm thinking of is organic transistors and printers.
When I finally I had the money for that, I did more or less the same. At that time I was buying on the counter. Later Internet came and things were different.tracecom,
I just took the shotgun approach when I ordered parts for a project and bought just about one of every CMOS IC the supplier listed on their website, more for those I knew I'd using.
You would never get even near on-par speed. This is the problem. Like, with a PIC μC running at 1MIPS, one direct port write takes up 1μS of time to execute.The idea of replacing some of these chips with a small micro is older than many are aware of. (Look in the very first application notes of Microchip).
Not even worth discussing about them. Have to see yet an application like that.
by Aaron Carman
by Aaron Carman
by Duane Benson
