24vdc to 300vdc adjustable regulated converter
bountyhunter
Joined Sep 7, 2009
2,512
Hmmm. I was thinking of capacitors in series. The capacitance does not add, but I think the working voltage does, since each capacitor in a series circuit "sees" half the applied voltage.
In theory, not in the real world. The voltage divides based on leakage current flowing through the caps. When we stacked them, we used a set of resistors alongside to force the voltage to divide.
tubeguy
Joined Nov 3, 2012
1,157
bountyhunter,
Thanks for the tip on LM2577. I'm going to experiment with it for various projects. I did get a 300v switcher design with the software, but it requires a custom high frequency transformer.
sgtwookie,
Great info on switchers. A lot of info on transformers.
It appears that to get 300 + volts from HF switchers requires HF ferrite transformers, not just simple inductors (that's what I was originally hoping to use). Is that correct?
The issue I have is I don't know where to get E-core transformer components
to wind-your-own or ready-made in small quantities.
Any ideas?
Thanks again for all the info.
bountyhunter
Joined Sep 7, 2009
2,512
bountyhunter,
You could check the references for what companies make the transformers listed in the simple switcher software data base.... they might have a standard item that would work. You might be able to sweet talk them out of a free sample.
bountyhunter
Joined Sep 7, 2009
2,512
You could build a "straight boost" to 300V but would have to use an external FET which can handle at least 400V ballpark. An IC won't get there, but you could use the IC to drive an external FET and it's pre driver if needed.
