Once again, after searching the threads, it doesn't look like this subject has been addressed.
At this moment, my home power system is based on generating 12V. However, I have the capability to change that to 24V, 48V or even 120 or 240AC if I want to spend the big bucks. I don't have the big bucks and debt is our enemy so, I am going to bring the hydro unit's charge rate up to 24V when I get a new 24V inverter in the near future. I have 4 - 6 volt deep cycle batteries that are now in series/parallel to provide 12V. It won't take much to switch them over to 24V.
Now this brings me to the reason for wanting to convert 24VDC to 24VAC.
My home security system is all 24VAC. And if I can eliminate the 120VAC to 24VAC transformer, then I should be able to run my security system straight from the batteries, so to speak. It would eliminate a power drain from my system and allow us to turn off the inverter while we are away.
Any thoughts or suggestions on how to do this? Or even better, where to find such a thing?
