24vDC motor
Discussion in 'General Electronics Chat' started by Georgeman12, May 4, 2015.
  1. Georgeman12
    May 4, 2015
    5
    So I've been asked to wire 7no. 24v dc motors. For switching a light load
    My question is if I wire between them and have one switching line back can these all be switched to operate the same time?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Motors, or relays?
  3. Georgeman12
    May 4, 2015
    5
    Motors
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    Are you asking if it is ok to wire 7 identical motors in parallel and use just one switch to control them?
    Georgeman12 likes this.
  5. Dodgydave
    Jun 22, 2012
    5,163
    774
    do you want to wire all the motors in parallel with a relay to switch them on at the same time?
  6. Georgeman12
    May 4, 2015
    5
    That's exactly what I'm going to be doing.a parallel connection for all piston motors. I'm just making sure it's completely possible using a 24v transformer and a relay for switching.
    http://www.elero-linear.com/images/36080561ff/Picolo_2012_EN_2011557_0113.pdf
    That's the actuators we are using
  7. Dodgydave
    Jun 22, 2012
    5,163
    774
    well as long as your relay contacts will take the current and voltage it will work.
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    I couldn't see the current rating on the spec sheet, But if switching all simultaneously I would use one of the DC rated power relays by P&B/Tyco PRD series that have magnetic blow out for arc suppression when using DC.
    Max.
  9. Georgeman12
    May 4, 2015
    5
    Thanks everyone!!
    Great help
  10. JWHassler
    Member
    Sep 25, 2013
    204
    34
    What is your application? How close together must the actuators be?
    I've used linear actuators before, and the speed-vs-load is not too well regulated.
    For that matter, the absolute speed is not specified too strictly... the datasheet says:
    djsfantasi likes this.
  11. Georgeman12
    May 4, 2015
    5
    They are about 500mm apart. There are 8 different banks of them each bank will have between 5 and 7 actuators
