24VAC Power Supply
Discussion in 'The Projects Forum' started by lesabb, Dec 30, 2014.
  1. lesabb
    Dec 30, 2014
    8
    Hello all,
    A bit of a noobie here (2nd year physics and electronics, bla, bla ,bla) mostly doing audio. I took apart a power module from a Mic pre-amp that uses a 24VAC wall adapter to run. After careful examination (it wasn't that complex actually) I came up with this schemo. Please let me know if it makes sense, did I miss anything? Looks ok to me but...Can I also replace the choke (circled) for a RC filter instead? This would supply +48V and +24 from the 24VAC. The 7824 hooks up to a 33v Zener. Values are not in the Eagle schem yet cause I wanted to make sure it was correct.
    L
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    C1 and C2 are most likely not capacitors.
  3. lesabb
    Dec 30, 2014
    8
    Thanks MrChips but I have the PCB right here in front of me. C1 is a Rubycon 1000uF/50V. C2 is 100uF/50V
  4. MrChips
    Oct 2, 2009
    12,624
    3,451
    Well I certainly wouldn't design a power supply like that.
  5. lesabb
    Dec 30, 2014
    8
    Any mods to suggest?
  6. MikeML
    Oct 2, 2009
    5,450
    1,066
    Why not? It is a standard way of making a rectifier/filter.
  7. ronv
    Nov 12, 2008
    3,393
    1,449
    It's a way to make a voltage doubler. I'm thinking the caps are non- polarized? Maybe not, just 1 cycle.
    I think you can replace the inductor with a wire or a low value resistor.
    edit: polorized
  8. MikeML
    Oct 2, 2009
    5,450
    1,066
    Yes, polarized. Look at the sim. Also, by playing with the ratio of C1 to C2, you can get anything from almost 2X voltage multiplication to less than 1X...
  9. ronv
    Nov 12, 2008
    3,393
    1,449
    I got a little different picture. Did I miss something?
      File size:
      115.1 KB
      41
  10. MikeML
    Oct 2, 2009
    5,450
    1,066
    I'm pulling a lot more current from the output. Also note my C1 and C2.
  11. ronv
    Nov 12, 2008
    3,393
    1,449
    Ahh yes, I see. I kept C2 low because he said he had a 48 volt supply.
  12. MrChips
    Oct 2, 2009
    12,624
    3,451
    Sorry, I didn't notice the 24V to 48V specs in the TS opening post.
