24v to 5v using optocoupler
Discussion in 'General Electronics Chat' started by ssiva, Apr 6, 2009.
  1. ssiva
    Apr 6, 2009
    5
    hi,
    i need simple circuit to switch 5v, from 24v dc. i have to drive a sensor having 5v operating supply from the plc 24v. thanks in advance
  2. mik3
    Feb 4, 2008
    4,846
    63
    Which PLC?
    Does the PLC has transistor or relay outputs?
  3. ssiva
    Apr 6, 2009
    5
    that is fatek plc, transistor type...
  4. mik3
    Feb 4, 2008
    4,846
    63
    Do you know where to find its datasheet online?
    You can use a transistor to make your job. Connect the transistor base to the output of the PLC via a 2K2 resistor, its emitter to ground and the load between the collector and 5V.
  5. ssiva
    Apr 6, 2009
    5
    thank you, can i use opto coupler instead of transistor?
  6. mik3
    Feb 4, 2008
    4,846
    63
    Yes you can.
  7. ssiva
    Apr 6, 2009
    5
    thank you very much
