24v to 12v
ammiel
Joined May 20, 2009
5
help i have a jeep and the batt voltage is 24 volt i need a schematic how to drop it become 12v cause may car stereo is 12v only any schematic tnx....
mik3
Joined Feb 4, 2008
4,843
A DC-DC converter would be the best solution due to its high efficiency. However, you can use a 10 Amp linear voltage regulator with a big heat sink.
ammiel
Joined May 20, 2009
5
yeah, you dont really build a switching power supply without some knowledge of electronics
i did say i dont have knowledge in electronic what i said is i'm not good on it its different.... i a'm a technician but not engineer that why i need a schematic so that i can make one
Wendy
Joined Mar 24, 2008
23,421
Even techs go forth and design, ocasionally. I'm a tech of 30 years, currently employed as an operator, and design from scratch all the time.
The 8 amps is a killer, but not unsurmountable.
Are you wanting to make a PCB, or are you prepared to do some breadboarding?
