24v to 12v led strip
Discussion in 'The Projects Forum' started by kenkay, Mar 21, 2016.
  1. kenkay
    Mar 4, 2013
    I have a 24v source and a strip of leds that need to run at 12v. I only have room to make a simple voltage divider to drop the voltage. I used 2, 100ohm resistors at 1/2W but they are getting way to hot. Any suggestions? Should I just bump up to higher wattage resistors?
  2. ronv
    Nov 12, 2008
    3,392
    1,449
    We will need to know the current of the led strip as well.
  3. TheButtonThief
    Feb 26, 2011
    219
    38
    Have you considered just using a LM7812?
  4. mcgyvr
    Oct 15, 2009
    4,784
    973
    Yep.. Need current draw of the LED strip..
    Or just buy a suitable 12V supply..
    They are cheap...
  5. blocco a spirale
    Jun 18, 2008
    1,457
    369
    Your resistors will dissipate the same amount of power as heat that the LED strip consumes and any linear voltage regulator will do the same.
  6. mcgyvr
    Oct 15, 2009
    4,784
    973
    Yep..
    Best solution is to buy the correct power supply or use a switcher type step down DC-DC converter which won't dissipate nearly as much heat as a linear solution.
  7. kenkay
    Mar 4, 2013
    Unfortunately we must have a 24v supply so I can't drop it to 12v. Current draw is .250 amps
  8. blocco a spirale
    Jun 18, 2008
    1,457
    369
    12V x 0.25A = 3W so you will need a 5W resistor.
  9. ronv
    Nov 12, 2008
    3,392
    1,449
  10. ameli
    Mar 21, 2016
    Hello..just use a switching voltage regulator using Lm2575or2576 ..no heat..no power lost
  11. mcgyvr
    Oct 15, 2009
    4,784
    973
  12. Dodgydave
    Jun 22, 2012
    5,136
    767
    Use an Lm2596 regulator chip.
