24V to 12V, 100W DIY Converter
Discussion in 'General Electronics Chat' started by R!f@@, May 8, 2016.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    I am looking for a schematic that any one made.
    I need to convert 24V to 12V at around 10A, output.
    A DC to DC converter will suffice, cause space limitation is there. Isolation is not needed.
    Any one made any ?
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    OK ! Me found one on a Zech site.
    I can translate all of the writings except one confusion.
    The caps say like 22nf, keram.
    I am guessing it is 22nf, ceram. As in ceramic.
    Am I right ?
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    And like to clear one more issue.
    How to figure out the wire thickness of the inductors.
    It says 70uH/10A. I guess from this one needs a formula to figure out the wire gauge.
    Any Pointers ?
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Keramic is Czech for ceramic.
    Google "Inductor design". It's a black art.
    R!f@@ likes this.
  5. kubeek
    Sep 20, 2005
    4,691
    806
    Yes, keram means ceramic cap.
    I think the author expects to buy an inductor that has the required inductance and can withstand the current. The rule of thumb for the wire is approximately 3A/mm2, so for 10A continuous you need roughly 3-4 mm2 wire, preferably multiple strands (both easier to wind and lower losses at high frequency).
    The saturation current of the inductor should be at least 12A.
    R!f@@ likes this.
  6. Andrew Hodson
    May 26, 2016
    5
    Guess you not got 50Ahr 12 volt battery around, & then just go from 1 to other.
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  8. kubeek
    Sep 20, 2005
    4,691
    806
    I can translate or clarify that, should anyone need.
  9. mcgyvr
    Oct 15, 2009
    4,794
    978
    Can you translate? "Both bertus and kubeek fooled by newbie Andrew bring back a post that was over days ago"
    Not necro but over..
  10. R!f@@
    Apr 2, 2009
    8,793
    771
    I already found the answer.
