24V PNP signal to Line driver converter
Discussion in 'General Electronics Chat' started by khatana, Feb 15, 2014.
  1. khatana
    Jul 17, 2013
    6
    Dear all,
    I want to convert 24V PNP signal to 5V line driver output.
    Is there any simple circuit or converter available?
  2. ScottWang
    Aug 23, 2012
    4,934
    777
    Try LM317.
    If you need to reducing the heat of LM317 then you can in series with a power resistor on the input of LM317, or you want to using LM2576-5.
  3. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi,
    A simple resistor 5.1V zener diode could work, what is the reduced 5V signal connected into?
    E
