24V neon decoration light effects?
Discussion in 'The Projects Forum' started by smilem, Nov 28, 2010.
  1. smilem
    Thread Starter Senior Member
    Jul 23, 2008
    133
    Hi, my Christmas lights controller (china made) went dead, obviously I would like to make them work again. I found some circutis on the net, but they all were LED based.
    Power source is: AC 24V wall adapter.
    Lights are: Neon lights (~19ohm per strand)
    There are 5 wires.
    Each strand pulls about 350mA (total 1.5A)
    Wire 1 is common wire
    Wires 2,3,4,5 make separate parts glow.
    Is there some 24V schematic I could use to make it blink, chase etc.
    Thank you.
  2. marshallf3
    Jul 26, 2010
    2,358
    201
    I have serious doubts that you've got neon lamps, just regular ones, so common sense applies.
    Can you measure ohmmage on the strings? Is the controller box trying to switch?
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
  4. smilem
    Jul 23, 2008
    133
  5. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,390
    Do you want some "flaming" in the lights?
    Almost all circuits in electronics are for DC.
    Your powersource is an 24 Volts AC wall adapter.
    Bertus
  6. smilem
    Jul 23, 2008
    133
    Well the adapter is made in Germany. It's not DC but AC 1.5A.
    I checked it by measuring, and it's written: AUSGANG 24V~ AC
    Furthermore the controller board had it's own bridge inside from 4 diodes.
    There were obviously 4 transistors to flash the lights and IC chip that is dead now.
    I can make a photo of the controller if somebody would help me reverse-engineer it to make it blink, flash etc.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    My guess is the voltage was converted into DC in the controller. From there that IC, which was probably a PIC, could do tricks. The transistors were to handle power.
    I also predict that the wire bundle had more than two wires, To allow for special effects.
    LEDs, 555s, Flashers, and Light Chasers
    Chapters 9 and 10. A microcontroller can do things with much less space.
  8. smilem
    Jul 23, 2008
    133
    So, here is the controller PCB, the hole in the center with 10 track going to it is the place where I desoldered another small PCB with the CHIP that was controlling it. I tried to see what it was but it was coated with black epoxy.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    The "black dot" was a chip on board integrated circuit. To save costs, rather than putting the IC into a package with leads, they simply put the ic onto the board, bring the leads out to the traces, and encapsulate it in epoxy.
    It was most likely a custom logic/uC IC. The driver transistors are still there, so any 4 output sequencer could be used to drive them and turn on the lights. See Bill's blog (link above) for ideas on how.
    If it hasn't been physically damaged, the sequencing board may be fine, and the transistors or power supply failed, would need more info and some measurements when it is assembled to have an idea though.
  10. smilem
    Jul 23, 2008
    133
    I have updated the PCB picture. I have marked PINS and tried to track them.
    Here is the updated PCB.
    I looked at Bill's blog and could not find 4 output sequencer, do you mean this:
    Chapter 9: Light Chasers
    I could connect the 4 outputs of IC 4022 to transistors (Pins 3,4,5,6) to drive the lamps right?
    http://pdf1.alldatasheet.com/datasheet-pdf/view/82916/UTC/PCR406.html
    What do I do with other pins how wire them?
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    SCRs do not work like transistors do, they stay on once turned on.
    The best way to do this would essentially be discarding that board, and starting over with a single mode sequencer. You could use one of Bill's Circuits for that, if there are more than 4 outputs, we can cut it down to 4.
    I am thinking of setting it up as a "chaser", where each LED would light in turn, 1-2-3-4, so the whole string would look like it is moving.
    Do you have a DMM? We'll need to voltage drop of the diodes in each of the 4 strings, I am guessing they are in parallel to support that many LEDs. Are all of the lights in each string the same color?
    The hardest part of making an LED chaser is usually getting the LEDs onto the wire in the right order. You have that part done.
