24V LDO Regulator
Discussion in 'General Electronics Chat' started by tracecom, Jul 16, 2012.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,878
    1,396
    I am looking for a LDO 24V regulator (1 A) and found an NTE1956, but Mouser only has two, and Digikey doesn't carry them. Is there a more common part available? I have about 1.3 V of headroom.
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  3. tracecom
    Apr 16, 2010
    3,878
    1,396
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  5. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Stand by one
    I give up
  6. bountyhunter
    Sep 7, 2009
    2,498
    507
    Check LM2941
  7. tracecom
    Apr 16, 2010
    3,878
    1,396
    Unless I am overlooking something, the LM2941 only goes up to 20V.
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    That's why I gave up. I had a hard time finding an adjustable LDO that would supply 1 A and had an input voltage in excess of 24 volts. It seems to be a tall order. The Fairchild and Siemmens parts that Bertus found look reasonable, but those companies are not the first that come to mind for LDO regulators.
  9. tracecom
    Apr 16, 2010
    3,878
    1,396
    It doesn't have to be adjustable. I just want a regulated 24V output from a 25.3VDC input. The datasheet for the LM7824 says the dropout voltage is 2V, but I wonder if it might work anyway.
  10. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I think it has to be adjustable because most vendors don't seem to be making fixed output 24V regulators. Never mind the LDO variety. The 7824 is a very old part, but it just might work for you. Also you should know that most fixed output regulators can be turned into an adjustable one.
  11. bountyhunter
    Sep 7, 2009
    2,498
    507
    Wierd. The input can go up to 26V, but the output can only go to 20V?
  12. bountyhunter
    Sep 7, 2009
    2,498
    507
    You could build a 24V LDO with this controller as long as the input voltage doesn't go above 26V.
    http://www.ti.com/lit/ds/symlink/lp2975.pdf
  13. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Can the OP handle the SMT package. I was looking for a 5-lead TO-220.
