24V from 12V power supply?
Discussion in 'General Electronics Chat' started by h.d, Feb 5, 2008.
  1. h.d
    Thread Starter Active Member
    Oct 22, 2007
    150
    hi
    i have relay with coil activation voltage (24Vdc)
    and my power supply output voltage is 12V(pc power supply)
    how can i get the 24V from that power supply?
    can i use voltage doubler?
  2. arthur92710
    Jun 25, 2007
    307
    If it has a +12 and -12 you can. +12 goes to + -12 is used instead of a ground.
    The distance between +12 and -12 is +24.:cool:
  3. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    A doubler will work, as long as it supplies sufficient coil current for the relay.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    As far as a doubler circuit goes; if you're talking about trying to simply use a couple of diodes and caps, no - that's for AC.
    In order to get 24v from a 12v supply, you'll need a "DC-DC converter", also called a "boost" or "step-up" converter.
    A DC-DC converter or boost converter has a chopper circuit (oscillator) that provides current to an inductor via a diode. The current flows for a bit, and then is cut off. This causes the inductor to pass current through another diode at a higher voltage. It's actually quite an efficent process.
    Here's a link to Wikipedia explaining the basics:
    http://en.wikipedia.org/wiki/Boost_converter
  5. h.d
    Oct 22, 2007
    150
    i think if i use the "boost" its need IGBT or MOSFET and trigger circuit
    to get the duety cylce,isnt it?
    if that true it will be more complicated that i need.
    in other hand in my circuit i rectify 220Vac by full bridge rectifier
    so i have 314Vdc,can i use voltage regulator to get the 24V,also i need 18Vdc too for another IC(MOSFET driver)?
  6. scubasteve_911
    Dec 27, 2007
    1,202
    No, You cannot use a simple voltage regulator to get your 24V nor 18V. Basic math dictates that even for a 25mA 24V supply, you'll get 7.25W dissipated from your regulator as heat. You will be very hard pressed to find any simple regulator that can accept that level of voltage anyways..
    A 12V to 24V boost regulator is a simple approach, just check out www.national.com and use their power simulation software, it isn't as hard as you think.
    Steve
  7. h.d
    Oct 22, 2007
    150
    thanks scubasteve_911
    i get it
    and that the schematic which dot from the national site.
    thanks for all replays.
      File size:
      25.2 KB
      297
  8. scubasteve_911
    Dec 27, 2007
    1,202
    That's it :) You just need to follow closely with their bill of materials by buying the recommended component or an equivalent. Make sure you do this though, ie. their 10uH inductor isn't replaced by another one without checking the saturation and DCR.
    Also, I'd layout according to their application notes or in the datasheet.
    Steve
  9. h.d
    Oct 22, 2007
    150
    yes i should foolow the recommended components,i hope to finde it in my country shops!!!
    hesham
  10. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    This would work if you can use a separate transformer (or separate secondary winding) and second rectifier bridge for the lower voltages.
  11. h.d
    Oct 22, 2007
    150
    thingmaker3,
    yes its able,by using 220:17 transformer to get 24dc then can use regulator or voltage divider to get 18Vdc.
    thank you
