24v dc transistor switching
Discussion in 'The Projects Forum' started by youngbossohene, Oct 16, 2014.
  1. youngbossohene
    Oct 15, 2014
    Hello guys am a new member here, and would like to receive some help. Am working on a printing machine project in which I have to use transistor switching circuit with an input of 24volts dc to switch on/off an actuator of 24v dc by means of a switch. Can anyone help me out with a circuit diagram?
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Can you just wire the switch in series with the actuator? If not, why not?
    Is this homework? If so, it should have been posted in the Homework Forum.
  3. youngbossohene
    Oct 15, 2014
    No it's not a homework assignment please. Am incorporating my design into a paper folding machine after the original electronic card controlling a knife blown up. Am using a paper sensor to control the actuator, but the load of the actuator will likely blow the sensor up. I used a 24v dc relay to do the power switching, but it's not switching fast enough because the machine is a high speed machine. That's why I want to use transistor switching instead to control the actuator.
  4. JDT
    Feb 12, 2009
    658
    85
    What current are you switching? How many amps.
    What kind of load? Motor, solenoid, heater?
    What sort of sensor are you using to control this switch?
    Exactly how fast does it need to switch?
  5. Alec_t
    Sep 17, 2013
    5,980
    1,138
    A MOSFET will probably be part of the solution, but we need answers to the questions in post #4.
