24v dc to 72v dc
Discussion in 'The Projects Forum' started by siriggy, May 14, 2007.
  1. siriggy
    May 14, 2007
    5
    Hi could anyone help, i have a UPS which has 6 x 12 v batterys in series. and i would like to charge it with 24v dc. can this be done.
    steve
  2. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Sure. If they physically fit, you could do three 24V batteries at the same AH rating.
  3. siriggy
    May 14, 2007
    5
    Hi joe what do u mean 3 24v batterys ain't all car batterys 12v
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Probably meant three groups of two batteries. Some antiques have 6V systems and some modern vehicles have 42 V systems. I've seen the 6V batteries, but I've never seen a 42V one.
  5. siriggy
    May 14, 2007
    5
    my inverter needs 72vdc, how can i charge the batterys with 24vdc from the bus alternator, if all the batterys are in series.
    steve
  6. siriggy
    May 14, 2007
    5
    would this circuit work
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The short answer is no. The only way I can see doing what you want is to change the configuration during charging. The charging voltage needs to be larger than the battery voltage in all cases that I am familiar with. Where exactly did you get this fancifal notion?
  8. JoeJester
    Apr 26, 2005
    3,402
    1,227
    I misread the question.
    Since you have a UPS, it already has a charging circuit to charge the battery pack [6 x 12]. Why would you want to charge them with a 24 volt supply?
    What is the problem with your UPS?
  9. siriggy
    May 14, 2007
    5
    i am converting a bus into a mobile home and want to use the ups as my 240vac supply but i need to charge it on the road, i will plug in in 240 at caravan park.
    steve
  10. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Get a small generator. Then you can charge the UPS as needed from wherever. Most Class "A" motor homes have small generators.
  11. Johann
    Nov 27, 2006
    190
    30
    Perhaps someone can come up with a DC to DC converter that will do the job? I did a google search on the topic, found many, but not in that voltage conversion range.
    It could be a challenge to try and convert a vehicle alternator to a higher voltage (with the correct regulation) and fit it as a second alternator to your motor home.
  12. JoeJester
    Apr 26, 2005
    3,402
    1,227
    Some owners of a Class A mobile home will run their generators while driving down the road to charge their UPS and run the roof top Air Conditioners instead of running the normal vehicle Air Conditioner.
