24v DC Linear actuator control
Discussion in 'The Projects Forum' started by shannon, May 5, 2011.
  1. shannon
    May 5, 2011
    If anyone can help, I have a linear actuator as below
    -24 V DC permanent magnet motor
    - Thrust up to 6000 N in push and up to 4000 N in pull
    -Duty cycle: Max 10% or 2 minutes continuous use
    followed by 18 minutes not in use
    -FLC 3.9A at 24v DC
    The application uses the actuator to open and close a shut off gate in a dust extraction system. I need to be able to use a current sensing device which can be cliped to the load side of a particular machine which when energised will open the gate, and once de-energised it will close the gate. Being a DC actuator the poles need to be reveresed when switching. I have simulated this using DPDT relays, but i need to be able to have somthing off the shelf, as it becomes quite time consuming as far as labour goes when there are multiple gates. If anynoe knows a standard way or an easier way of dealing with this i would much appriciate the help.​
  2. Kermit2
    Feb 5, 2010
    3,845
    963
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    http://www.rockler.com/blog/index.cfm?mode=entry&entry=7F49233B-1372-6771-F65F39FF671D8B87 But, really the opposite of what you want. :(
    http://www.amazon.com/M-Bright-iVac-Automated-Vacuum-Switch/dp/B0035YGLZG/ref=sr_1_6?s=hi&ie=UTF8&qid=1304648289&sr=1-6 This to detect the current. The output drives a 120VAC DPDT relay. The relay with your 24VDC supply controls the actuator. This assumes the actuator has internal limit switches.
    http://electronicaircleaners.com/aprilaire-51.aspx Like Kermit2 said. Switches a relay that switches the DC supply that switches the actuator direction.
    Ken
