24v control/test box
Discussion in 'The Projects Forum' started by servo, Oct 28, 2011.
  1. servo
    Aug 11, 2011
    31
    Hey, all. I've got a project that I need to do for work, but I'm not sure where to start. I need to design and build a box that will run on and put out 24 VDC, but also be able to put out +/- 10 VDC. It will also need to have test points to monitor the signals on the pins of a 12 pin connector. It's a breakout box combined with a power supply and control function, I guess. My main problem is the power supply. How do I pull +/- 10 VDC from +24VDC?
  2. mcgyvr
    Oct 15, 2009
    4,791
    976
    Just reverse the leads.. We use a +48VDC supply at work and just by reversing the leads you get +48 or -48VDC.
    So a 24 V isolated supply plus a 10V regulator circuit.
    What current level do you need for the -/+10V?
  3. servo
    Aug 11, 2011
    31
    Never more than 2 amps. I had a problem with this circuit before where there seemed to be a grounding issue. I could not get the circuit to work properly and I was getting some strange voltages where they shouldn't be. This was using a 12V regulator and a switch to reverse the leads.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I remember that thread. Here: http://forum.allaboutcircuits.com/showthread.php?t=58057
    If you must power the +/-10v supplies with 24VDC, you will need to use switching regulators that have galvanically isolated outputs; something like this:
    http://search.digikey.com/us/en/products/PTB78560CAH/296-20363-ND/789181
    If you have anywhere from 100VAC to 240VAC available, you could probably use a pair of these:
    http://www.mpja.com/12VDC-2A-Regulated-Plug-Supply-Jasper/productinfo/18776+PS/
    12v, 2A regulated switching plug supplies.
  5. servo
    Aug 11, 2011
    31
    Thank you, SgtWookie. And thank you for your previous help. I'll look at the links you sent me.
  6. servo
    Aug 11, 2011
    31
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, with 24v in, the PD412 model will give you ±12v @ 40mA maximum; is that going to be sufficient? (better stay at 80% or less of that maximum rating; so <=32mA)
  8. servo
    Aug 11, 2011
    31
    The current draw on the control circuit is negligible. 2 or 3mA maximum. 40mA should be more than enough, not to mention a heck of a lot cheaper.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Note that you need to maintain a minimum load on those supplies.
    Use a 2.4k resistor from each out ±12v terminal to the output common terminal.
  10. servo
    Aug 11, 2011
    31
    Ah, yes, I see that. I'll be sure to do that.
  11. servo
    Aug 11, 2011
    31
    The isolated converter works like a dream. Thanks for all the help!
  12. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Cool beans! Glad you finally got it working. ;)
